AlexAnkrah
OverView Map Widget Help!
Discussion created by AlexAnkrah on Jul 1, 2011
Latest reply on Sep 14, 2012 by amarsden
Right I thought I had this cracked but apparently not!
I sometimes get one of these two errors or both
1. 'esri.bundle.widgets' is null or not an object
2. 'wkid' is null or not an object
Below is my current implementation of the OverView widget. Anything I'm doing wrong?
dojo.connect(this.GISmap, 'onLayerAdd', jQuery.proxy(function() {
            this.afterLoad();
        }, this));
afterLoad: function() {
var overviewMapDijit = new esri.dijit.OverviewMap({
map: this.GISmap,
baseLayer: layer,
visible: false,
attachTo: "top-right",
expandFactor: 2.5
overviewMapDijit.startup();
I have tried other approaches including the two below but the above errors keep coming up. Any pointers please?
if (this.GISmap.loaded) {
map: this.GISmap,
baseLayer: layer,
visible: false,
expandFactor: 2.5
else{
//nothing.
This other approach just gives errors usual errors (but works in a simple map app!!)
                   var createOverviewMap = function() {
                       map: this.GISmap,
                       baseLayer: layer,
                       visible: false,
                       color: "#D84E13",
                       width: 300,
                       height: 250,
                       expandFactor: 2
                       dojo.style(dojo.byId("status"), "display", "none");
                   if (layer.loaded) {
                       createOverviewMap();
                   else {
                       dojo.connect(layer, "onLoad", createOverviewMap);
Also See
http://forums.arcgis.com/threads/31709-Effectively-adding-baseLayer-to-OverView-Map?highlight=overview+map
Outcomes
