Help with repairing data source
549
6
06-20-2011 06:52 AM
OliverMorris
New Contributor III
I have been trying to get this code to work for the last couple of hours, if anyone could give me some help that would be great.
I would like to repoint any broken links to a new table that lies within a personal geodatabase. The code I have is:
import arcpy, os
path = r"N:\Temporary_Work\Oliver Morris\EDCOLLINS_ISOPACH"
for fileName in os.listdir(path):
    fullPath = os.path.join(path, fileName)
    if os.path.isfile(fullPath):
        basename, extension = os.path.splitext(fullPath)
        if extension == ".mxd":
            mxd = arcpy.mapping.MapDocument(fullPath)
            print "MXD: " + fileName
            brknList = arcpy.mapping.ListBrokenDataSources(mxd)
            for brknItem in brknList:
                 lyr.replaceDataSource (r" N:\Temporary_Work\mapping_2011.mdb",        "ACCESS_WORKSPACE", SEA_110617)
                 print "\t" + brknItem.name
del mxd
When I run this I get the error - Runtime error <type 'exceptions.NameError'>: name 'SEA_110617' is not defined
Can you please point me in the right directions.
Oliver
JeffBarrette
SEA_110617 is the name of a feature class, not a variable.  It therefore should be in quotes.  Change it to "SEA_110617".
Your code below is changing all broken layers to be the same source.  Is that what you really want.
Also note - if SEA_110617 is a raster dataset you may not be able to repair it.  We just found an issue with rasters.  We will address it at SP3.
import arcpy, os
del mxd
OliverMorris
New Contributor III
Thanks for your reply, when I try to run this I now get the error below
>>> import arcpy, os
... path = r"N:\Temporary_Work\Oliver Morris\EDCOLLINS_ISOPACH"
... for fileName in os.listdir(path):
...     fullPath = os.path.join(path, fileName)
...     if os.path.isfile(fullPath):
...         basename, extension = os.path.splitext(fullPath)
...         if extension == ".mxd":
...             mxd = arcpy.mapping.MapDocument(fullPath)
...             print "MXD: " + fileName
...             brknList = arcpy.mapping.ListBrokenDataSources(mxd)
...             for brknItem in brknList:
...   lyr.replaceDataSource (r"N:\Temporary_Work\Oliver Morris\EDCOLLINS_ISOPACH\Isopach_mapping_2011.mdb","ACCESS_WORKSPACE","SEA_ODM_ISOPACH_110617")
... print "\t" + brknItem.name
... del mxd
MXD: ISOPACH_EDIT1_EDCOLLINS.mxd
Runtime error <type 'exceptions.NameError'>: name 'lyr' is not defined
Any idea why this is not working.
Many Thanks,
Oliver
OliverMorris
New Contributor III
I have also tried this as well but get the following error:
import arcpy, os
  for lyr in brknItem:
   lyr.replaceDataSource (r" N:\Temporary_Work\Oliver Morris\EDCOLLINS_ISOPACH\Isopach_mapping_2011.mdb","ACCESS_WORKSPACE","SEA_ODM_ISOPACH_110617")
del mxd
but get the error:
Runtime error <type 'exceptions.AttributeError'>: LayerObject: Get attribute layers does not exist
Many Thanks for your help
JeffBarrette
That is most likely because you have a layer type (e.g., group layer) that doesn't support "replaceDataSource".  You should look at the help topic for layers, specifically the "supports" parameters.  It explains all of this.  I modified the code below (and removed an unnecessary if statement).
import arcpy, os
                if brknItem.supports("DATASOURCE"):
                    lyr.replaceDataSource(r" N:\Temporary_Work\Oliver Morris\EDCOLLINS_ISOPACH\Isopach_mapping_2011.mdb","ACCESS_WORKSPACE","SEA_ODM_ISOPACH_110617")
del mxd
OliverMorris
New Contributor III
Thank you for your continued help with this. I ran your code but it returned an error any idea why.
Many Thanks,
Oliver
>>> import arcpy, os
...                 if brknItem.supports("DATASOURCE"):
...                     lyr.replaceDataSource(r" N:\Temporary_Work\Oliver Morris\EDCOLLINS_ISOPACH\Isopach_mapping_2011.mdb","ACCESS_WORKSPACE","SEA_ODM_ISOPACH_110617")
... del mxd
JeffBarrette
The error message says it all "lyr" not defined.
You have lyr.replaceDataSource when it should be brknItem.replaceDataSource
Jeff
