royceverboom
Python Crash Help
Discussion created by royceverboom on Jun 13, 2011
Latest reply on Jun 14, 2011 by royceverboom
Hello all,
I wrote up a script that takes a set of points from a SQL db and turns each set of points into lines in a new shapefile that is created in the script. I also create a new field to import from the db (the name of the line).  I am debugging with Eclipse and when I run the script, it creates the shapefile correctly, but it crashes python when its done.
Any reason for this, or way to avoid it?  It is hard to get something automated if it crashes =/
Outcomes
