Python - Relationship Classes
5829
5
06-13-2011 03:01 PM
AlvaroMoreno
How do i list the Relationship Classes with python ?
For tables, datasets and featuresClass use ListTables, ListDatasets and ListFeatureClasses.
DavidWynne
Hi Gonzalo,
Yes, it's possible using Describe and it's children property.  children will return a list of subelements from a workspace.
So, if you use a bit of code like below, this will return a list of relationship class names.
workspace = "c:/data/gdb.gdb"
rc_list = [c.name for c in arcpy.Describe(workspace).children if c.datatype == "RelationshipClass"]
-Dave
MelanieRosenberg2
Occasional Contributor II
I have consulted the post above, but found that the solution is out of date and no longer works.
import arcpy, os workspace = r'C:/Users/OWNER/Desktop/test.gdb'# Generate the list of relationship classesrc_list = [c.name for c in arcpy.Describe(workspace).children if c.datatype == "RelationshipClass"]print rc_list
This returned "[]" which is an empty array. This means this is no longer a viable option since I have literally 150 relationship classes to rename and none were returned.
Eventually I want to rename my relationship classes as such:
import arcpy, osfrom arcpy import env # Set workspaceenv.workspace = "C:/Users/XXX/Desktop/test.gdb" #get list of relationship classesrc_list = [c.name for c in arcpy.Describe(env.workspace).children if c.datatype == "RelationshipClass"]   #remove all underscoresfor rc in rc_list:    out_data = rc.replace("_","")    arcpy.Rename_management(os.path.join(env.workspace,rc), out_data)#get the list of relationship classes againrc_list = [c.name for c in arcpy.Describe(env.workspace).children if c.datatype == "RelationshipClass"] for rc in rc_list:       #    if "reading" in rc OR "action" in rc:        #add underscores between name and ATTACHREL        if "ATTACH" in rc:            out_data = rc.replace("ATTACHREL","TblGPS__ATTACHREL")            arcpy.Rename_management(os.path.join(env.workspace,rc), out_data)            print (rc)         #add underscores between name and rel        if "rel" in rc:            out_data = rc.replace("rel","TblGPS__rel")            arcpy.Rename_management(os.path.join(env.workspace,rc), out_data)            print (rc)    else:        #add underscores between name and ATTACHREL        if "ATTACH" in rc:            out_data = rc.replace("ATTACHREL","PtGPS__ATTACHREL")            arcpy.Rename_management(os.path.join(env.workspace,rc), out_data)            print (rc)         #add underscores between name and rel        if "rel" in rc:            out_data = rc.replace("rel","PtGPS__rel")            arcpy.Rename_management(os.path.join(env.workspace,rc), out_data)            print (rc)
How can I extract the relationship classes from the geodatabase so I can rename them in bulk? I have them in a file geodatabase right now but eventually I will have them in SDE.
Michael_RMiller
Dwynne from Esri posted a bit of code on another post that might help. Cf.:
arcpy.ListRelationshipClasses() | GeoNet
AlvaroMoreno
In my case the workspace is of type RemoteDatabase.
looking at the help but not can find that case
you can pass me the code in this case ?
thanks
gonzalo
DebbieBull
Gonzalo,
I think you just need to specify your SDE Connection File rather than the .gdb path
workspace = r"DatabaseConnections\Connection to dbInstance.sde" or some such.
Debbie
