Spatial Analyst Conditional Function Window Problem
2525
06-06-2011 02:26 AM
deleted-user-RFr3Mv3Cb0aR
Using ArcInfo V10, SP2. When attempting Con, Pick, Set Null functions in the SA conditional functions toolbox, the Expression cannot be set as the functions don't recognize the input raster, ie. no fields are visible. The SQL button causes a Query Builder window to pop-up but this is fully non-functional as fields are not available. Same results when trying to run this through Model Builder or stand-alone.
Any reason for this? In V9.3 I had no problems
Paul Roberts
DanPatterson_Retired
key word search.... dot notation raster
In version 10, it currently isn't supported
http://forums.arcgis.com/threads/16689-using-raster-attribute-other-than-value-in-map-algebra
the key word search will provide other links
Thank You for the quick reply! (and please forgive my late response). The information was exactly what I needed.
strange...are we in some space-time vortex?
