loyers
Is a bug of measurement ????? help me!
Discussion created by loyers on May 25, 2011
Latest reply on May 25, 2011 by DSwingley-esristaff
hi: there is some thing wrong with the measurement widget, the code as felow:
i user js api of 2.3.
if (measurement != null)
    measurement.destroy();
measurement = new esri.dijit.Measurement({
                map: map
            }, dojo.byId('apDiv1'));
measurement.startup();
// measurement  is a  Global  object
// this code may be called many times , the first once it  work right , but the second.......   it does not work right
the excption is :
  tride to register widget with id == apDiv1 but that id is already gegisterdineNumber;
but before i   new  the measurement  object   a alread call its  "destroy();" , does not  the "destroy();"  work ???
or is it a bug ???  How do i do it ?
thank you.
Outcomes
