lipsc1sw
Turn Troubles
Discussion created by lipsc1sw on May 25, 2011
Latest reply on Jul 13, 2011 by jborgion
Hi all, I'm relatively new to this extension.  I've been reading up on it on in the web based help section.  However, I can't seem to figure out the turn part.  Basically, the network I have has a few turns in it that are illegal, so I want to restrict them.  I set turns as one of the parameters under the network dataset.  I create the turns that aren't legal, and rebuild the dataset.  When I try to solve some test locations, the route always goes through these turns that are restricted.  If I try to use the turn features as a line barrier it just blocks the route from going anywhere.  Maybe I'm creating the turn wrong?  I start creating it on the "from direction" edge, then the junction the turn is at, and then finish it up with the "to direction" edge.
I know it's something small I missed, but I can't seem to figure it out.  Any help would be much appreciated.
Sam
Outcomes
