tryagaaa
UIToolControl on a VBA form?
Discussion created by tryagaaa on May 24, 2011
I have same problem with this post
[HTML]http://forums.esri.com/Thread.asp?c=93&f=992&t=112228[/HTML]
But when I following the step from the post
I receive a error message says
"object required"
following is my code
Private Sub CommandButton4_Click()
Dim pApp As Application
Set pApp = Application
Dim pCommandItem As ICommandItem
  Set pCommandItem = m_pApp.ThisDocument.CommandBars.Find("Project.UIToolControl1")
  Set m_pApplication.CurrentTool = pCommandItem
End Sub
The error is happen in
how to fix it??
i have solved problem here
Set pCommandItem = pApp.Document.CommandBars.Find("Project.UIToolControl1")
Set pApp.CurrentTool = pCommandItem
but there's an other problem
when I click the button in the form
it's can't change to the map that I can choose the Point on the map!!
following is my UITool code
Private Sub UIToolControl1_MouseDown(ByVal button As Long, ByVal shift As Long, ByVal x As Long, ByVal y As Long)
Dim pMapp As IMxApplication
Dim pSDisplay As IScreenDisplay
Dim pPoint As IPoint
Set pMapp = Application
Set pSDisplay = pMapp.Display
Set pPoint = pSDisplay.DisplayTransformation.ToMapPoint(x, y)
MsgBox "X" & pPoint.x & "_" & "Y" & pPoint.y
End Sub
please help me out!!
Outcomes
