does not fill the serviceDescription variable of the mapServiceInfo object, it does however successfully retrieve the name and layer of the service. When I check the url in the browser it cleary has a serviceDescription. What am I doing wrong here?
(The URL given in the piece of code is not the real URL used, this is just about the code whether I'm missing something) The server is version 10 SP2, the ArcGIS API for IOS used is 1.8 final.
I hit the same issue in another function. It seems like there's a few areas where you can actually pass-in an error (which makes no sense). My guess, is that it's good practice to initialize any NSError objects to nil when using the ArcGIS API.
