AnsweredAssumed Answered
How can I draw a freehand polygon?
Question asked by kenbuja on May 10, 2011
Latest reply on May 11, 2011 by kenbuja
I'm creating an Add-in that lets a user select the type of feature to draw on the map. I've gotten the code for adding points, polygons, and rectangles, but I'd like to add in the capability of drawing polygons in freehand mode. Is there way of doing that? Here's my existing code for the drawing tool
Public Class DrawTool
    Inherits ESRI.ArcGIS.Desktop.AddIns.Tool
    Public Sub New()
    End Sub
    Protected Overrides Sub OnUpdate()
    End Sub
    Protected Overrides Sub OnMouseDown(ByVal arg As ESRI.ArcGIS.Desktop.AddIns.Tool.MouseEventArgs)
        MyBase.OnMouseDown(arg)
        Dim activeView As ESRI.ArcGIS.Carto.IActiveView = My.ArcMap.Document.ActiveView
        Dim rgbColor As ESRI.ArcGIS.Display.IRgbColor = New ESRI.ArcGIS.Display.RgbColorClass()
        Dim pGeometry As ESRI.ArcGIS.Geometry.IGeometry5 = GetFeatureFromMouse(activeView)
        rgbColor.Red = 255
        'Add the user's drawn graphics as persistent on the map.
        AddGraphicToMap(activeView.FocusMap, pGeometry, rgbColor, rgbColor)
        'Best practice: Redraw only the portion of the active view that contains graphics.
        activeView.PartialRefresh(ESRI.ArcGIS.Carto.esriViewDrawPhase.esriViewGraphics, Nothing, Nothing)
    End Sub
    Public Sub AddGraphicToMap(ByVal map As ESRI.ArcGIS.Carto.IMap, ByVal geometry As ESRI.ArcGIS.Geometry.IGeometry, ByVal rgbColor As ESRI.ArcGIS.Display.IRgbColor, ByVal outlineRgbColor As ESRI.ArcGIS.Display.IRgbColor)
        Dim graphicsContainer As ESRI.ArcGIS.Carto.IGraphicsContainer = CType(map, ESRI.ArcGIS.Carto.IGraphicsContainer) ' Explicit Cast
        Dim element As ESRI.ArcGIS.Carto.IElement = Nothing
        graphicsContainer.DeleteAllElements()
        If (geometry.GeometryType) = ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryPoint Then
            ' Marker symbols
            Dim simpleMarkerSymbol As ESRI.ArcGIS.Display.ISimpleMarkerSymbol = New ESRI.ArcGIS.Display.SimpleMarkerSymbolClass()
            simpleMarkerSymbol.Color = rgbColor
            simpleMarkerSymbol.Outline = True
            simpleMarkerSymbol.OutlineColor = outlineRgbColor
            simpleMarkerSymbol.Size = 8
            simpleMarkerSymbol.Style = ESRI.ArcGIS.Display.esriSimpleMarkerStyle.esriSMSCross
            Dim markerElement As ESRI.ArcGIS.Carto.IMarkerElement = New ESRI.ArcGIS.Carto.MarkerElementClass()
            markerElement.Symbol = simpleMarkerSymbol
            element = CType(markerElement, ESRI.ArcGIS.Carto.IElement) ' Explicit Cast
        ElseIf (geometry.GeometryType) = ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryPolyline Then
            '  Line elements
            Dim simpleLineSymbol As ESRI.ArcGIS.Display.ISimpleLineSymbol = New ESRI.ArcGIS.Display.SimpleLineSymbolClass()
            simpleLineSymbol.Color = rgbColor
            simpleLineSymbol.Style = ESRI.ArcGIS.Display.esriSimpleLineStyle.esriSLSSolid
            simpleLineSymbol.Width = 5
            Dim lineElement As ESRI.ArcGIS.Carto.ILineElement = New ESRI.ArcGIS.Carto.LineElementClass()
            lineElement.Symbol = simpleLineSymbol
            element = CType(lineElement, ESRI.ArcGIS.Carto.IElement) ' Explicit Cast
        ElseIf (geometry.GeometryType) = ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryPolygon Then
            ' Polygon elements
            Dim simpleFillSymbol As ESRI.ArcGIS.Display.ISimpleFillSymbol = New ESRI.ArcGIS.Display.SimpleFillSymbolClass()
            simpleFillSymbol.Color = rgbColor
            simpleFillSymbol.Style = ESRI.ArcGIS.Display.esriSimpleFillStyle.esriSFSForwardDiagonal
            Dim fillShapeElement As ESRI.ArcGIS.Carto.IFillShapeElement = New ESRI.ArcGIS.Carto.PolygonElementClass()
            fillShapeElement.Symbol = simpleFillSymbol
            element = CType(fillShapeElement, ESRI.ArcGIS.Carto.IElement) ' Explicit Cast
        End If
        If Not (element Is Nothing) Then
            element.Geometry = geometry
            graphicsContainer.AddElement(element, 0)
        End If
    End Sub
    Public Function GetFeatureFromMouse(activeView As ESRI.ArcGIS.Carto.IActiveView) As ESRI.ArcGIS.Geometry.IGeometry5
        Dim screenDisplay As ESRI.ArcGIS.Display.IScreenDisplay = activeView.ScreenDisplay
        Dim pPointSymbol As New ESRI.ArcGIS.Display.MarkerFillSymbol
        Dim pRGBColor As New ESRI.ArcGIS.Display.RgbColor
        Dim pPolygonSymbol As New ESRI.ArcGIS.Display.SimpleFillSymbol
        Dim pOutline As New ESRI.ArcGIS.Display.SimpleLineSymbol
        Dim pRubberBand As ESRI.ArcGIS.Display.IRubberBand2
        Try
            Select Case Globals.DrawFeatureType
                Case "Point"
                    pRubberBand = New ESRI.ArcGIS.Display.RubberPoint
                 Case "Polygon"
                    pRubberBand = New ESRI.ArcGIS.Display.RubberPolygon
                Case "Rectangle"
                    pRubberBand = New ESRI.ArcGIS.Display.RubberEnvelope
                Case "Freehand"
                    System.Windows.Forms.MessageBox.Show("Freehand not coded yet")
                    Return Nothing
                Case Else
                    System.Windows.Forms.MessageBox.Show("Not coded yet")
                    Return Nothing
            End Select
            pGeometry = pRubberBand.TrackNew(screenDisplay, Nothing)
            Return pGeometry
        Catch ex As Exception
            System.Windows.Forms.MessageBox.Show(ex.ToString, "Get Feature")
            Return Nothing
        End Try
    End Function
End Class
Outcomes
