rmuellerjr03
Addin deployment Crash
Discussion created by rmuellerjr03 on May 6, 2011
Latest reply on May 9, 2011 by mike.robb
Has anyone run to problems with deployment of an add in? The dockable window works just fine on my machine (with no debug errors in VS 2008), but struggles in the client environment. There are no symptoms other than ArcMap 10 crashing either on the client machine.
For deployment, I had clients use the "double click" method of deployment,  which allows for the placing the button on a toolbar. However rather than the dockable window appearing, ArcMap crashes.
Does anyone know how to test for look for problem symptoms? I am going to try to create and deploy an ESRI sample to see if I get the same errors in the mean time.
Outcomes
