Issue using "Generate From/To Node for Lines" with ArcGIS 10 desktop
1993
05-02-2011 09:42 AM
SusanMoore
New Contributor III
Cross-posting this from here = http://forums.arcgis.com/threads/29159-Issue-using-quot-Generate-From-To-Node-for-Lines-quot-with-Ar...
I'm trying to run the Generate From/To Node for Lines against a water network. I've been able to run other ArcHydro tools against this data without issue (e.g., Set Flow Direction, Store Flow Direction, Assign Hydro ID). However, every time I try to run Generate tool, I receive the error shown at the end of this post. Not sure if the path to the C drive is a clue? It doesn't exist on my PC.
After the tool throws the error, I can see that the FROM_NODE and TO_NODES fields have only been updated for 5000 of the 50434 features. Anyone have any suggestions?
I'm using ArcGIS 10 desktop (Info license), SP1.
Susan
SusanMoore
New Contributor III
Sorry, didn't include the error in the earlier post:
Executing: GenerateFNodeTNode WaterCourse
Start Time: Wed Apr 27 10:16:27 2011
Populating FROM_NODE and TO_NODE fields...
50434 features processed and 51945 nodes identified.
If your input table was already opened, you may need to close and reopen it to view the updated FromNode/ToNode values.
SetFromToNode,-289 System.Runtime.InteropServices.COMException (0x80041055): Exception from HRESULT: 0x80041055
at ESRI.ArcGIS.Geodatabase.IFeatureCursor.UpdateFeature(IFeature Object)
at ESRI.APWR.ApHydro.GDBHelper.SetFromToNodeDict(IFeatureClass pFC, Int32 debug, ITrackCancel& trackcancel, IGPMessages& messages, String& exMessage, String FromNodeFld, String ToNodeFld, String& sMsg, String sPrecisionFormat) in C:\Projects\10_Final\ArcHydroTools\src\ApHydro\GDBHelper.vb:line 2258, 50434
Failed to execute (GenerateFNodeTNode).
Failed at Wed Apr 27 10:18:01 2011 (Elapsed Time: 1 minutes 34 seconds)
