andrewbrown
Mobile Tools in a GPServer
Discussion created by andrewbrown on May 2, 2011
Latest reply on May 11, 2011 by andrewbrown
Using ArcGIS Server 10 SP1 - Enterprised Advanced
I've published a GPService from a toolbox containing two models. One is using the create mobile map tool and the other is using synchronize mobile cache.
When I try to execute or submit job (synchronous / asynchronous) respectively, I recieve errors that the tool is invalid. Error 000816 Code 500. "The tool is invalid"
Tools can be run within ArcMap and work fine.
My mxd is on a share with the SOC account having modify permissions through share along with change permissions through NTFS security for both map and cache folders.
Toolbox is published from a different share with SOC account also having modify permissions through share and ntfs.
Does anyone know if using these Mobile Tools in a Published ArcGIS Server GPServer service is restricted or does anyone have any thoughts on why they don't execute?
Andrew
Outcomes
