I am using the attribute inspector dijit to edit feature attributes. Several of these fields have domains associated with them. When a feature is selected, those fields are rendered as a dropdown with the correct domain values, as expected. However, if the field has a value already, the value is not selected in the dropdown. Instead, it is highlighted as though the field were null or had an invalid value (which it does not).
The field values match the domain values, so why doesn't the attribute inspector show the correct value?
The other fields without domains are populated with their corresponding values.
