Move FeatureClass to FeatureDataset
1082
04-28-2011 04:19 AM
JohnMcGlynn
I am creating a Network and as part of it I have to create a featuredataset called NETWORK and then I have to move an existing FeatureClass into the NETWORK featuredataset.
The code I am trying to use is:
Private Sub moveToDataset(ByVal sName As String, ByVal sToDatasetName As String, ByRef sError As String)
        ' Move a featureclass to be "within" a feature dataset
Using pComReleaser As New ESRI.ArcGIS.ADF.ComReleaser
  Dim pDatasetContainer As IDatasetContainer
        Dim pFeatureDataset As IFeatureDataset
        Dim pdataset As IFeatureDataset
Try
sError = ""
    pFC = g_pFNetWorkspace.OpenFeatureClass(sName)
    pComReleaser.ManageLifetime(pFC)
   ' Get the dataset
    pdataset = g_pFNetWorkspace.OpenFeatureDataset(sToDatasetName)
    pFeatureDataset = pFC.FeatureDataset
    pComReleaser.ManageLifetime(pFeatureDataset)
    pDatasetContainer = pdataset
    pComReleaser.ManageLifetime(pDatasetContainer)
    pDatasetContainer.AddDataset(pFeatureDataset)
   Catch ex As Exception
      sError = "ERROR: moveToDataset; Line: " & Erl() & vbCrLf & ex.Message
End Try
End Using
End Sub
The problem I keep getting is "Attempted to write protected memory" when the AddDataset line
is processed.
The Feature dataset has been created beforehand using the Spatial Reference of the featureclass
I am trying to move into it. Might that be a problem?
Am I going about this the right way? I can copy the featureclass (row-by-row) into the feature dataset so nothing appears to be wrong with it.
J
JohnMcGlynn
I've fixed it now and the process was quite a bit simpler than I expected:
Dim pFC As IFeatureClass
Try
sError = ""
pFeatureDataset  = g_pFNetWorkspace.OpenFeatureDataset(sToDatasetName )
' Get the FeatureClass
pDatasetContainer = cType(pFeatureDataset, IDatasetContainer)
pDatasetContainer.AddDataset(pFC)
End Try
End Using
End Sub
