Is there a specific method or process to distribute a Personal Geodatabase with a Setup.exe or Installer.msi? I'd like to distribute a PGDB that my extension uses with the .msi that is built for deploying the assembly.Are there any specific suggestions on AppPath settings? For example, I have some code that opens an IFeatureWorkspace of that PGDB:pWorkspaceFactory.OpenFromFile(db_path & "\Reporting.mdb", 0)
I guess my question on AppPath would be where exactly would the Installer set AppPath?Edit: here is my current GetAppPath function:
Private Shared Function GetAppPath() As String
Dim path As String
path = System.IO.Path.GetDirectoryName(System.Reflection.Assembly.GetExecutingAssembly.Location)
Return path
End Function
