How to find the midpoint of a polyline?
10506
9
04-26-2011 07:52 AM
RenField
Can anyone share with me the easiest way to calculate the midpoint of a polyline on a graphics layer?
TIA
JenniferNery
polyline.Extent.GetCenter();
deleted-user-0W0-oLHxDjCX
New Contributor III
I think you will not get a midpoint if the line is irregular.
New Contributor III
Actually the truecentroid property will give you a gravity center of an irregular polyline but if you want to reach the middle point of a feature you have to do something else.
The picture above is wrong. The centroid property will give you the nearest point from centroid (actually, within the polyline).
Sincerely
Ezequias.
New Contributor III
You can do it in Arcpy but I did not find any reference in Javascript.
// Arcpy
Midpoint = geometry.positionAlongLine(0.50,True).firstPoint
... print Midpoint.X
... print Midpoint.Y
JenniferNery
I think this will be the runtime equivalent method then: GeometryEngine.CreatePointAlong Method
New Contributor III
Nice to know. Unfortunately I am in a Javascript challenge
ScottDavis3
Try the code below. The get_length is another function that just uses the geometryEngine length function. This works for a single part polyline.
function midPointPolyline(line) {
var path = line.paths[0];
var seglen = get_length(line, "feet");
var midLen = seglen / 2;
var currentDistance = 0;
var beforeIndex = 0;
var startPoint = line.getPoint(0, 0);
for (i = 1; i < path.length - 1; i++) {
var nextPoint = line.getPoint(0, i);
var d = geometryEngine.distance(startPoint, nextPoint, "feet");
if (currentDistance + d < midLen) {
currentDistance += d;
startPoint = nextPoint;
} else {
beforeIndex = (i === 1) ? 0 : i;
break;
startPoint = line.getPoint(0, beforeIndex);
var endPoint = line.getPoint(0, beforeIndex + 1);
var x = (startPoint.x + endPoint.x) / 2;
var y = (startPoint.y + endPoint.y) / 2;
var midpt = new esri.geometry.Point({ x, y, spatialReference: { wkid: line.spatialReference.wkid } });
return midpnt;
AndyWhitaker1
New Contributor III
(Deleting double post)
AndyWhitaker1
New Contributor III
Hi @ScottDavis3.  With your help, I was able to get a working solution.  Thank you!  Seems this would be built into the ArcGIS API for JavaScript?!
I have made a couple of changes to Scott's code.  Most notably, I had to change get_length() to geodesicLength() in the geometryEngine class because I couldn't find get_length().
The code below utilizes the ArcGIS for JavaScript 3.x version.
function getPolylineMidPoint(polyline) {
	const path = polyline.paths[0];
	const length = GeometryEngine.geodesicLength(polyline, "feet"); // esri.geometry.geometryEngine
	const middleLength = length / 2;
	var startPoint = polyline.getPoint(0, 0);
	for (let i = 1; i < path.length - 1; i++) {
		var nextPoint = polyline.getPoint(0, i);
		var d = GeometryEngine.distance(startPoint, nextPoint, "feet");
		if (currentDistance + d < middleLength) {
		} else {
			break;
	startPoint = polyline.getPoint(0, beforeIndex);
	const endPoint = polyline.getPoint(0, beforeIndex + 1);
	const x = (startPoint.x + endPoint.x) / 2;
	const y = (startPoint.y + endPoint.y) / 2;
	const midPoint = new Point({ x, y, spatialReference: { wkid: polyline.spatialReference.wkid } }); // esri.geometry.Point
	return midPoint;
function doTest () {
	const query = new Query(); // esri.tasks.Query
	query.where = "Type='Tunnel'";
	self._someLayer.queryFeatures(query,
		(fs) => {
			const features = fs.features;
			const midPoint = getPolylineMidPoint(features[0].geometry); // utilizing the midpoint function
			const location = webMercatorUtils.webMercatorToGeographic(midPoint); // esri.geometry.webMercatorUtils
			const symbol = new SimpleMarkerSymbol( // "esri.symbols.SimpleMarkerSymbol"
				SimpleMarkerSymbol.STYLE_CIRCLE,
				15,
				new SimpleLineSymbol( // "esri.symbols.SimpleLineSymbol"
					SimpleLineSymbol.STYLE_SOLID,
					new Color([0, 0, 255, 0.5]),
					8
				new Color([0, 0, 255]) // esri.Color
			const graphic = new Graphic(location, symbol); // esri.Graphic
			self.map.graphics.add(graphic);
		(err) => {
			console.log("Error: " + err);
