How to list which feature layers are being used by which web maps and apps?
3650
5
10-30-2020 11:53 AM
ConorMacNaughton
Anybody got any tips or hints on how this can be done?
I've been able export lists of items by user and user folder using the following:
pd.DataFrame(list_items).transpose().to_excel(str(user.username)+'.xlsx')
But it would be more useful to see which web maps and web apps throughout my organization are using which feature layers.
DavidPike
MVP Frequent Contributor
I'm still learning this one myself, quite painfully in fact...
Accessing and creating content | ArcGIS for Developers
Working with web maps and web scenes | ArcGIS for Developers
here's what I could glean from the documentation (such as it is..)
from arcgis.gis import GIS
from arcgis.mapping import WebMap
gis = GIS(url='https://pythonapi.playground.esri.com/portal',
username='arcgis_python',
password='amazing_arcgis_123')
search_my_contents = gis.content.search(query="owner:[owner name]",
item_type="Web Map", max_items = 1000)
#create web map objects from search results and print the web map title and layer name
for webmap_item in search_my_contents:
    webmap_obj = WebMap(webmap_item)
    for layer in webmap_obj:
        print(webmap_item.title, layer.title)
ConorMacNaughton
Thanks! This worked for me after the following change to line 14:
for layer in webmap_obj.layers:
anonymous55
Occasional Contributor II
Hello I changed line 14 but I am getting this error
  Input In [1]
    print(webmap_item.title, layer.title)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
SyntaxError: invalid non-printable character U+200D
I am running this code in AGOL notebook.
Basically, I want my code scan web maps in my portal and list all layers and there map services url
ZakBaron
New Contributor III
I got the same error,
and found this:
https://www.decodingweb.dev/solved-syntaxerror-invalid-non-printable-character-in-python
I removed the non-printable characters using Notepad++ with this method from StackOverflow (https://stackoverflow.com/questions/20889996/how-do-i-remove-all-non-ascii-characters-with-regex-and...)
'In Notepad++, if you go to menu Search  Find characters in range  Non-ASCII Characters (128-255) you can then step through the document to each non-ASCII character.
Be sure to tick off "Wrap around" if you want to loop in the document for all non-ASCII characters.'
After that, it worked like a charm!
JosephRoberts2
Hi David,
Have you figured out how to access the properties of a sublayer of a service?  For instance, I'm iterating through a map that has the entire service. When my script hits this layer, it does not iterate through the sublayer of the services. It simply prints the name of the main service.
Any insight would be greatly appreciated.
