Editing not enabled
1686
10-23-2020 04:41 AM
OscarDiago_Alonso
New Contributor III
Good morning!
I'm building a plugin for ArcGis Pro that performs several editions over a File GeoDatabase.The first step are populate several of the feature classes and tables inside that File GeoDatabase. I have zero issues with it, but the person who will use it keeps getting this error:
I have no idea why the "Editing in the application is not enabled" is happening. That error message appears when a non-geometric table is written (the last step). Before that, several features classes are updated the same way without any problem.
I use the same code for every insert method, so I don't understand why the last method is giving that error to that person and it is working fine on my side.
  Public Async Function storeMetadata(metadatos As METADATOS, gdbPath As String) As Task(Of Boolean)
        Dim message As String = String.Empty
        Dim creationResult As Boolean = False
        Await QueuedTask.Run(Function()
                                 Using geodatabase As Geodatabase = New Geodatabase(New FileGeodatabaseConnectionPath(New Uri(gdbPath)))
                                     Using gca_metadatos As Table = geodatabase.OpenDataset(Of Table)("GCA_Metadatos")
                                         Dim editOperation As EditOperation = New EditOperation()
                                         Try
                                             editOperation.Callback(Function(context)
        Using rowBuffer As RowBuffer = gca_metadatos.CreateRowBuffer()
        rowBuffer("IDTRANSACCION") = metadatos.IDTRANSACCION
'More fields here
        Using row As Row = gca_metadatos.CreateRow(rowBuffer)
        context.Invalidate(row)
        End Using
        End Using
        End Function, gca_metadatos)
                                         Catch ex As Exception
                                             MessageBox.Show("Error guardar metadatos (I): " & ex.Message)
                                         End Try
                                         Try
                                             creationResult = editOperation.Execute()
                                             If Not creationResult Then message = editOperation.ErrorMessage
                                         Catch exObj As GeodatabaseException
                                             message = exObj.Message
                                             GCA_Common.Application.EscribirError(GCA_Common.Application.AlmacenarError(exObj))
                                         End Try
                                     End Using
                                 End Using
                                 Return True
                             End Function)
        If Not String.IsNullOrEmpty(message) Then
            Return False
        Else
            Return True
        End If
    End Function‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Thanks for any help provided!
by Anonymous User
Not applicable
Oscar,
That editoperation error message usually indicates editing has been disabled in the UI, either by the user or via the SDK. Can you check if this is the case, if not we'll have to look into it further. Is the user allowed to interact with the UI before the last table is updated in your app?
The following links describe how editing can be disabled in the UI:
Enable and disable editing—ArcGIS Pro | Documentation
ProConcepts Editing · Esri/arcgis-pro-sdk Wiki · GitHub
by Anonymous User
Not applicable
Oscar,
OscarDiago_Alonso
New Contributor III
I will check this. But it would be strange if it is activated for the Feature Classes and not for the Table. The user doesn't interact with th UI during those editions.
Thanks for your input!
OscarDiago_Alonso
New Contributor III
Thanks! That solved the problemn. The customer had different Editing options enabled in ArcGIS Pro Settings.
