I want to calculate the valley floor width to valley height ratio of a basin
1444
10-15-2020 03:52 AM
MariaForte
I've been trying to calculate the valley floor width to valley height ratio of a lot of basins, I'm fairly new at using ArcGIS so I tried using a already made tool I was recommended that you can find here: github-ValleyMorphTool but it does not work, it finds errors in every basin I have and skips them, even in the test package that comes with the tool it doesn't seem to work, I'm using ArcGis 10.7 and I noticed the tool was tested on 10.1, could that be the reason it's not working? If so could someone tell me some other way to calculate it?
emench
I've been having a similar issue. I tried using ValleyMorph on 10.8 and the toolbox will not install so I think it is a version issue. Have you been able to find an alternative method?
AllanLopez
