OpenStreetMap Exceptions on zoom
925
10-14-2020 01:58 AM
YaronAvraham
New Contributor III
I'm using OpenStreetMap as a base map in 100.8 SDK with visual studio 2019,
when i'm doing fast zoom in or fast zoom out i'm getting alot of  "The request was aborted" web exception which are causing real slowdown when they are thrown.
any idea why i'm getting these exceptions?
MichaelBranscomb
Esri Frequent Contributor
You will only see those exceptions when the debugger is attached. Try running without the debugger attached to see actual experience/performance.
Mike
YaronAvraham
New Contributor III
Hi, Thanks for the answer,
Yes i understand that i will see the exceptions only in debug mode, i do know that exception handling in .NET is quite expensive performance wise,
when i detach the debugger the performance is much better, but i can still sense some slowdown when i do fast zoom in/out,
any plans on fixing that in future releases?
