wmcb8367
Sample Code Mashup
Discussion created by wmcb8367 on Apr 11, 2011
Latest reply on Apr 14, 2011 by wmcb8367
I'm trying to use parts of the code from the "Legend With Visible Layers" sample (found in Widgets: http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm) and code from the "Editor" sample (found in "Editing") to create a legend in the accordion container that updates its contents depending upon which layers are on or off, but which I can select features from to drop on the the map to create new records (e.g., the location of a recent 911 call).  Is this possible or are these two things too self contained to take pieces from like this?
If this will not work I would like to put the editor feature in another accordion container, but I'm not sure where the editor code should go - should it fit inside of the "init" function or should it go outside by itself? Thank you in advance!
Outcomes
