mulitple map questions
416
10-13-2020 12:47 PM
DanielMeaney
New Contributor III
I want to have multiple map questions but seems I am not allowed in the web designer version.  Seems odd for a map-oriented survey package.  I basically want to ask:
- Pick your favorite place in the community
- Pick your least-favorite place
I could use an additional question to have the user describe each one, but can't figure out how to use the map twice?
Shwu-jingJeng
Hi Daniel,
You can achieve this by using Survey123 Connect and pick the sample "Multiple Geopoints" using null fields as a reference for your survey design.
DanielMeaney
New Contributor III
So ... if I've already built most of the survey in the web designer interface, I would have to start over with 123 Connect?
Shwu-jingJeng
Hi Daniel,
No, you can log in to Connect using the same login account and the surveys you created from web designer should also appear in Connect as well. You can then edit the same survey using Connect. But remember, once you edit the survey in Connect, you won't be able to edit the survey in web designer anymore.
