michel.turmelcgi
Using a Renderer to override the symbology coming from the map service
Discussion created by michel.turmelcgi on Oct 9, 2020
I am in the process of creating my first custom 2 D widget and I can dynamically add a layer on the map , but as soon as I try to add a renderer to override the symbology coming from the map service then the layer does not show on the Layer List anymore and I get no error message
Here is my environment:
   - Portal for ArcGIS version 10.6
   - Web AppBuilder Developer Edition 2.6
   - ArcGIS JavaScript API 3.33
Here is part of my code: as soon as I had the lines in bold then the layer does not show anymore:
I have defined:
define(['dojo/_base/declare',
  'jimu/BaseWidget',
  'dojo/on',
  'esri/layers/FeatureLayer',
  'esri/renderers/SimpleRenderer',
  'esri/symbols/PictureFillSymbol',
  'esri/Color',
  'esri/map',
  'esri/dijit/Legend'
function(declare,
        BaseWidget,
        on,
        FeatureLayer,
        SimpleRenderer,
        SimpleFillSymbol,
        Color,
        Map)
  //To create a widget, you need to derive from BaseWidget.
  return declare([BaseWidget],
    baseClass: "test",
_onBtnTestClicked: function()
var comp1 = test1.value;
      var template = new esri.InfoTemplate();
      var comp1OperatorLayerURL = "https://........";
      var comp1OperatorfeatureLayer = new esri.layers.FeatureLayer(comp1OperatorLayerURL, {
        outFields: ["*"],
        opacity: 0.5,
        infoTemplate: template,
        mode: esri.layers.FeatureLayer.MODE_SNAPSHOT,
        definitionExpression: comp1OperatorSearch
      comp1OperatorfeatureLayer._titleForLegend=comp1OperatorfeatureLayer.title=comp1OperatorfeatureLayer.name=comp1Operator;
      // set the symbology
      var symbol = new esri.symbol.SimpleFillSymbol().setColor(new esri.Color([255,0,0,0.5]));
      var renderer = new SimpleRenderer(symbol);
      comp1OperatorfeatureLayer.setRenderer(renderer);
      map.addLayers([comp12NonOperatedOVOperatedfeatureLayer,...]);
Outcomes
