ArcGIS Dashboards and feature services from a federated GIS server
590
10-10-2020 01:48 PM
FraserHand
Occasional Contributor III
HI,
When trying to create a gauge from a feature service accessing a SQL db from a federated GIS server that is not the hosting server I see this:
edit:
Same service from 2 different GIS servers - hosting server and federated server
The layer does have query enabled and supports advanced statistics. I don't see this if I published the same service to the hosting server.
Has anyone seen this before?
Derek Law
DerekLaw
Esri Esteemed Contributor
Hi Fraser,
Is this using the current ArcGIS Dashboard release or ArcGIS Dashboard beta?
Sorry, but I haven't seen this type of behavior before. It might be a bug. Can you please open an issue with Esri Tech Support so they can help investigate further?
Hope this helps,
FraserHand
Hi Derek,
It's 10.8.1 - upgraded from 10.5.1. All patches applied. This is using the default ArcGIS Dashboard App built into the Enterprise Portal.
Fraser
