Editing leader anchor point in Map Graphics
1095
10-08-2020 02:43 AM
DustinEdge1
Hi All
I'm using Pro 2.6.1 and while the Map Graphics is a great addition to the toolset, I'm stumbling on a simple thing.
I created a bunch of rotated multi-line boxed callouts BUT cannot seem to edit/move the anchor point once it's created.
(the green vertex in the attachment).
This was very easy to do in ArcMap.
Anyone came across this before?
And before anyone asks "why not use an annotation FC instead"? It's because I only had a handful of labels and wanted to test the new Map Graphics functionality.
Thanks in advance
Dustin
TomBole
Hi Dustin,
This is likely a bug.  Can you contact Esri Support? They are better equipped to handle troubleshooting steps and gather bug data. They can be contacted at https://support.esri.com/en/contact-tech-support.
Tom
DustinEdge1
I figured this out. When there's a rotation angle on the map frame I can't edit/move the anchor point.
But if I reset it to north-up then I can move it easily.
I did log a ticket with them so they might file it as a bug. Let's see.
IANMACPHERSON
Thank you so much for your post, I'm better able to cope with this frustration. I had expected ESRI to retain the ArcMap functionality for callouts and leaders , but surprise, they didn't.
