Publish mosaic dataset as map service
1396
6
10-07-2020 11:22 AM
SoratoSouza_e_Silva
Occasional Contributor II
How can I publish a mosaic dataset as a map service, without using an Image Server license?
Thank´s
Arcgis Server 10.8
Tags (1)
George_Thompson
Esri Frequent Contributor
Not sure it is possible without the Image Server extension. You could export the Mosaic Dataset into an Raster dataset and publish it as a single image.
Publishing image services—ArcGIS Server | Documentation for ArcGIS Enterprise
--- George T.
SoratoSouza_e_Silva
Very good I will try tomorrow. I will announce the results here
Thank´s
by Anonymous User
Not applicable
Hi
Another way you might try is to build map-cache and publish it as a map service.
Regards,
Bing
SoratoSouza_e_Silva
Thank you very much for your guidance.
I have a doubt, my images are more than 2.5 TB, is it possible to publish? Is there a limit to publishing as a map service?
SoratoSouza_e_Silva
AndreasB
Were you able to publish the services without the extension?
