Heat Map Date Selector
466
10-06-2020 02:44 PM
NatalieKovach
How do I make a heat map respond to a date selector? Right now a point map works fine with the date selection tool but the heat map doesn't respond to any date changes and I have set the applicable action items under the date selector.
by Anonymous User
Not applicable
Hi @NatalieKovach , I am having the same problem.
It seems to be a bug reintroduced with the new ArcGIS Dashboard. This post has more comments, so you may want to follow it in case Esri posts a solution there: https://community.esri.com/t5/arcgis-dashboards-questions/heat-map-style-will-not-update-based-on-da...
