Bug: body::esri:visible not working for image or audio questions
1068
10-06-2020 12:58 AM
LaurenceTait
Occasional Contributor II
The body::esri:visible option doesn't have any effect on image or audio questions. These types of questions can be made invisible by placing them into a group, and rendering the group invisble. But on their own, the body::esri:visible option has no effect at all.
BrettStokes
Hi Laurence,
Since hiding questions using the body::esri:visible column is currently a beta feature, this post would be better placed on the Early Adopter forum. That way it could potentially be addressed before the body::esri:visible column is officially supported. This behaviour is because image and audio questions are actually attachments to the feature service, but is definitley a valid enhancement. Thanks for identifying this, I'll update the Early Adopter documentation to list it as a known limitation for now.
Brett
TL2
Occasional Contributor III
This blog seems to illustrate that image questions are supported under body::esri:visible but I am still seeing image questions when I try and use it on version 3.15 connect.  Is this still not supported and is there a work around?
https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-hidden-relevant-an...
LaurenceTait
Amazing that years later ESRI still hasn't addressed this bug despite the functionality becoming standard.
You'll have to use the same solution we've all been using for 2 years - put the image into a group and hide the group.
JoãoMartins1
And it still not working on "file" questions.
I think it wasn't registered as a BUG.
