Time slider configure time broken
452
10-07-2020 05:15 AM
VictorTey
Hi, can someone tell me why Configure time setting seem to be gray out for me.
I have test 2.16 and 2.15 and tested on 3 different machine across IE, Edge and chrome.  But my setting page is gray out
JayJohnsonWashoeCounty
Occasional Contributor III
Victor,
Are you sure that you have a time-enabled layer in your map?  It isn't enough to just have date/time data in the layer, you have to set the layer properties prior to publishing the service.
The configuration of the widget is disabled if there are no time-enabled layers in the map.
Set the time properties on data—ArcGIS Pro | Documentation
Jay
Jay
Washoe County GIS
VictorTey
Jay Johnson‌ Yes, and the time slider widget is working as well . Just that configuration is gray out.
Enterprise 10.7.1
