Finding the records that participate in a relationship
497
10-01-2020 07:16 AM
HanliePretorius
New Contributor III
I had to replace one FC with another and at the same time I created another relationship class.
I started with old_property_fc and old_valuation_table with 1:M old_property_valuation_relationship.
Then I created new_property_fc and new_valuation_fc and 1:M new_property_valuation_relationship.
The trouble is that some of the features in new_valuation_fc seem to be related to features in old_property_fc. I think I know how it happened - operator error! - but now I want to find all the features in new_valuation_fc that are related to old_property_fc records.
Is there some way of doing this? Both FCs have 40 000+ records, so doing it manually will be an arduous task.
I'm comfortable with SQL if that helps.
Tags (1)
DanaNolan
Occasional Contributor III
It sounds like you can join-by-attribute the old property records to the new feature class table, assuming the field that is used in the relationships to link tables is usable. When you start a join from the many side (table), it should find all the one side (feature) records that match.
If the link field cannot be used to match the records, you will have to look at other fields and/or clean up the data until you get a single field that can match old records to new features.
HanliePretorius
New Contributor III
Hi Dana,
Thanks for the reply.
In the end I used something similar to what you describe, except I did
it straight in SQL.
This is the code I used:
select vs.PropertyID
, vp.PROPERTY_ID as VALUATIONPROPERTY
, p.PROPERTY_ID as PROPERTY
from new_valuation_fc vs
left outer join
old_propery_fc vp
on vp.PROPERTY_ID = vs.PropertyID
left outer join
new_property_fc p
on vs.PropertyID = p.PROPERTY_ID
where p.PROPERTY_ID is null
That gave me everything in the new_valuation_fc linked to PropertyIDs
that do not exist in the new_property_fc.
I had some help from a colleague with this and it seemed to do the trick.
Cheers
Hanlie
2020-10-26 19:38 GMT+02:00, Dana Nolan <geonet@esri.com>:
Dana Nolan
replied
to the discussion
"Re: Finding the records that participate in a relationship"
To view the discussion, visit:
https://community.esri.com/message/961154-re-finding-the-records-that-participate-in-a-relationship?commentID=961154&et=watches.email.thread#comment-961154
