AnsweredAssumed Answered
project las
Question asked by marapanagiotidou on Oct 1, 2020
Latest reply on Oct 5, 2020 by jjohnson_washoe
Hi there,
I work with building foortprint and ground contour shp files in Projected Coordinate system WGS_1984_World_Mercator. I also brought a las file of the area but that one is available in the Coordinate system GDA_1994_MGA_Zone_55. Inside the ArcGIS environment, the building polylines, the terrain contours and the las data seem to overlay correctly, however, ArcGIS does the ‘projection on the fly’. While I can use the tool ‘Project’ to change the projected coordinate system of a layer to another, it seems I can’t do the same with las files. The only way I came up with to project the las points to WGS_1984_World_Mercator was to covert las to multipoints, and then add a new field with the points’ height.
Is there a more appropriate way to project las points to another coordinate system. I would also like to export the data as points or coordinates. Is there a tool that exports las files to xyz coordinates?
Thanks!
Cheers,
Maria
Outcomes
