copy raster from gdb to .TIF causes pixel shift
794
09-25-2020 09:26 PM
EmikoCondeso
New Contributor III
I exported a file geodatabase raster to .TIF format using "copy raster" (ArcGIS Pro, not sure what version, but the work was done on whatever release was current in April 2020) and found there was a pixel shift of about 7m to the left (raster has 10 m pixels). Today I tried to replicate this problem (ArcGIS Pro version 2.6.1) and could not reproduce the error.  Can anyone help shed light on what might have caused the shift?
Thank you!
DanPatterson
MVP Esteemed Contributor
There have been issues noted with half cell pixel shifts, for example
BUG-000110431: Copying and pasting a raster to an enterprise geodat..
The "cell alignment" environment setting was recently introduced to account for this
Cell Alignment (Environment setting)—ArcGIS Pro | Documentation
Tools that support it like copy raster support this environment setting
Copy Raster (Data Management)—ArcGIS Pro | Documentation
If you want to know when the difference occurred you would have to examine the "whats new" section of the help
Release notes for ArcGIS Pro 2.6—ArcGIS Pro | Documentation
or the tech support documentation
... sort of retired...
EmikoCondeso
New Contributor III
Thank you for your help.  Is this bug documented for file geodatabases?  The linked bug report referred to enterprise gdbs.
DanPatterson
Emiko Condeso‌ Don't know if the bug applies to file gdb but all that it means that the only report was for enterprise.
The real take-away is the Cell Alignment considerations which allows you to fine-tune how extents and raster cells creation can interact.
Sadly, this aspect is overlooked by many and it isn't necessarily consistent among other gis software or in translations of rasters to other forms of raster representation.
