Unpublish-able Survey
976
09-27-2020 06:52 PM
JamesBailey
I am experiencing difficulties publishing a new free text field within a repeat.
When I try to publish it recognises the field I am trying to publish (below).
But it sits here spinning indefinitely.
I came across the below, where it may struggle to publish if the change is only within a repeat.
So I added 4 extra hidden/meta data questions. It sat there indefinitely but when I forced closed it, Survey123 recognise there was a new version but the question in the repeat was not there. When I republish its still found and tries to publish again.
Is this a bug, have I done something wrong?
Cheers
JamesTedrick
Esri Esteemed Contributor
Hi James,
Did you add the new questions to parent layer of the form?  The note you are referring to is regarding re-publishing when only repeats have new fields added to them.
JamesBailey
The four hidden questions I added were not within a repeat.
