Webmaps not showing up in collector
1320
09-22-2020 02:46 PM
RachelGugler
I made a new webmap for Collector today, but the option to allow for use in Collector is missing in the settings. It is still visible in the older maps I created earlier this summer. My boss is doing the Field Maps beta and can see the maps in his Field Maps, but not Collector as well. Is this a bug or did something change on how you access maps in Collector in the last month?
New Map
Application Settings inside new Webmap I just created. Collector box is missing.
Old Map
Application Settings inside webmap I made several months ago. Collector box is present.
Kylie
by Esri Regular Contributor
The first thing I would check is that the new map contains an editable layer. And if it does, but that layer was recently made editable, try saving your map again.
Esri Education Team
by Anonymous User
Not applicable
+1 for missing editable layer. Fastest way to check is to see if there's an 'Edit' button in the Web Map Viewer.
Here's a couple of techical articles that go into more depth and provide additional solutions:
Problem: ArcGIS Collector does not display web maps created in Portal for ArcGIS
Problem: Unable to view a web map in Collector for ArcGIS
Cheers,
Chris
KMuthRC
I had the same issue, where a new web map with new editable layers was created, I was unable to open the map within Collector.
I found that once i manually created some random data in the new layers it appeared in Collector.
