Survey123 Instance id error with Choice filter present
990
09-22-2020 03:26 AM
PaulSweeney3
Occasional Contributor III
Hi All
I have an xls form that uses choice filters across a number of section lists. Just recently i have been met with this error
"The same instance id will be generated for different external instance source URLs. Please check form. Instance name 'Machinery', Existing type: 'pulldata', Existing URL: 'jr://file-csv/Machinery.csv', Duplicate type: 'choice', Duplicate URL: 'None', Duplicate context: 'survey'"
the strange thing is if i remove the choice filter the form loads fine. the csv it references in the error  was previously included in the form but it was removed and is no longer in use.  there are other pulldata csv in the form. Has anyone come across this error before?James Tedrick‌ perhaps you may know something abut this error?
Regards
Paul
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Paul,
It would be helpful to see the entire form folder (XLSX, XML & CSV files) to see what is going on.  On a first read, it seems like you may have 2 files that are close in naming (i.e, 'Machinery.csv' and 'machinery.csv') or are using columns in the choice_filter with similar names.
JamesTedrick
Hi Paul,
PaulSweeney3
Hi james
Can I add you to a group or is there another way I can share it with you. I d rather not post it here
PaulSweeney3
Hi James Tedrick
The issue is resolved as you mentioned there was duplication in the choice filter i had missed . Thanks for your response.
