importing mr. Sid. 24GB..six hours and counting what gives?
1284
09-21-2020 03:27 PM
JohnRay1
Using ArcMap:  Issue:  Received an Aerial Photograph of Oneida County, WI from the county and it is a Mr Sid format and exceeds 24 GB.  I did copy it to my solid state drive first, and then tried importing it as a raster in ArcCatalog and after three hours of chugging away, I cancelled the process, which after three more hours I went to bed and found it had finally finished cancelling sometime that night.
I read somewhere that the Mr. Sid files should not be imported directly but should be converted to a TIFF, so this morning, again in ArcCatalog, I tried to convert before importing.  Here I am over four hours later and still chugging, I think.  At no point did the program ask me what format to convert to...it just started chugging away again.   Guess I will just let it keep chugging along until I am heading off to bed tonight and will hit the cancel button again.
Clearly, I will need to clip this ultra large aerial photograph in order to use it in ArcMap, or maybe building pyramids will suffice,
My Questions:
  1.  Is this file too large for ArcMap? If so, is there another program I can use to clip it?
  2. If ArcMap can handle it, how do I proceed to import it to my file geodatabase?
  3.  Once it is imported, how do I clip it without needing hours (days) to process?
  4.  Where is the progress bar? If you had a progress bar, I could at least monitor my progress and decide to tough it out or abort.
DanPatterson
MVP Esteemed Contributor
How much ram do you have?
What does it look like in Windows Resource Monitor or Performance Monitor?   (Windows Administrator tools)
... sort of retired...
JohnRay1
Hey Dan: I have 16GB RAM….I have been running for 16 hours now trying ESRI’s suggestion of importing the MR.Sid into a new File Geodatabase… Have notified them of this time gobble or failure and am awaiting their next move. Cheers, jR
Sent from Mail for Windows 10
JohnRay1
Arc just finished the task…failure. Here is the error message. Cheers, jR
JohnRay1
Dan: just as a follow up…apparently MrSid’s can be directly dragged into an active Map Document and do not require being imported into a Geodatabase. If there are other complications from short circuiting the procedure, I have yet to discover any. So, cheers, jR
