Custom transformation for raster mosaic dataset
813
09-21-2020 03:24 AM
StephanieGoudeseune
I have a raster mosaic with datasets of +100 custom coordinate datasets.
In the properties > Defaults > Coordinate System Transformation, I have an issue:
- I know there are +100 transformations, but in the overview I only have 26 listed. The mosaic is visualising properly, so I assume that all transformations should be in this list. Imagine I want to troubleshoot and delete a transformation from the list, I cannot do this because it is not in the list
- This brings me to the 2nd issue: When I want to add a transformation, I can add it via the dropdown and '+' on top. I noticed that I cannot add any other transformation from this dropdown. After clicking OK > OK, and reopening the window, I see the transformation I added is not visible in the list.
Does anyone have an idea what can be the issue?
Attachment made in 2.4.2 but I have the same issue in 2.6.0.
PeterBecker
Best if you send this to support. They should be able to dig into this in more detail.
StephanieGoudeseune
Thank you, we have sent this to support
