Local Server SDK Package unavailable after installation
1532
7
09-20-2020 10:09 PM
Arun_PrasadRamanujadoss
New Contributor III
Hi Everyone,
I am building a WPF application using ArcGIS Runtime .NET SDK with access to local File Geodatabase. For this I have downloaded and installed the ArcGIS Local Server SDK as recommended in the Guide.
After successful installation of Local Server SDK the Visual Studio NuGet Package manager couldn't able to find the Local Server SDK in the system. Also I have reviewed the Esri Package folder in its path ( C:\Users\AppData\Local\Esri\NuGet )  there also the Local Server file is missing. All other ArcGIS runtime SDK's .nupkg files are present in that folder
Kindly help me resolve this issue and guide me.
dotMorten_esri
Esri Notable Contributor
Sorry I misread that question. After some more coffee, I think I know what you're saying now 🙂
The local services SDK isn't installed with the VSIX. It's available on nuget.org. Did you pick nuget.org in the dropdown?
dotMorten_esri
Which version of the Local Server SDK did you install, and which version of the Nuget Packages are you using? (they should/must match)
dotMorten_esri
New Contributor III
Thanks.. got it from nugget.org source. Not sure why the installation didn’t worked though.
MichaelBranscomb
Esri Frequent Contributor
Do you mean the installation of Visual Studio didn't work or the installation of ArcGIS Runtime SDK for .NET didn't work?
Mike
New Contributor III
No. I meant to say that local Server SDK is not installing the nuget package.
But I now understand that it’s supposed to act that way as explained by Morten Nielsen‌.
dotMorten_esri
Note: The installation doesn't include the Local Server SDK, and that is by design. Is that what you mean by "didn't work" that it wasn't there ? Because that is intended
New Contributor III
Yes. I thought since the downloads page mentions it as SDK it will also download the nugget package file.
But I now understand that VSIX file is the way to install the nuget package.
Once again thanks for clarifying.
