arcgis online: unable to change the "choose an attribute to show" when WFS layer
550
09-18-2020 12:42 PM
julienrobitaille
New Contributor III
I am experiencing some problems when I want to "select an attribute to show for a WFS layer. As you can see, the option in the section "change style" of the layer is just not there, even if the WFS layer has been loaded correctly. Is there a way to solve this issue? Thanks !
Thanks for your help!
ManishPatel
Hi julien robitaille,
I think what you are trying to set the symbology is not possible at the moment.
See the documentation on Change Style reference—ArcGIS Online Help | ArcGIS
There is an idea submitted in ArcGIS Ideas Change Style for OGC WFS Layer on ArcGIS Online.
Hope this helps.
Cheers,
Manish
Cheers,
Manish
julienrobitaille
New Contributor III
Thank you for your answer. Do you know if any ESRI products can actually manipulate WMS and WFS layers and publish them on the web with a easy to use layout configuration (atually, something like ArcGIS online, but with more options for WFS)?
Thank again!
Julien
