Change records in Incident Detector processor
832
09-16-2020 11:16 PM
nasserhinai
Dear,
I have used the Incident Detector processor to get an incident record but the incident record has a very different schema from the event record I routed to the processor and I lose a bunch of attributes from the original record.
So is there any soultion to not change the attributes between input and output from Incident Detector processor ?
Nasser
MatejVrtich
you should be able to use the Event Joiner processor immediately after the Incident Detector to join the schemas and preserve the attributes.
Regards,
Matej
AdamMiller4
New Contributor III
Matej,
I see this recommended in the online documentation as well, but can't find an example anywhere.  I'm not able to get it configured correctly.  Are there example service configurations out there?
Adam
by Anonymous User
Not applicable
Hello Adam,
Not sure if this issue still is problematic for you. However there is a use case example that may help here:
Kind regards,
Marc
