Storymaps Slideshow- Audio option?
632
09-16-2020 10:08 AM
CindyHamfler3
If I put a slideshow in my story map, I currently don't see an option to add audio.  Am I missing something or is this option only available in sidecar block?  Any plans to allow audio in slideshows in future? My slideshow was to highlight different animal species and an audio clip of what each animal sounds like would be so cool!
AbbyE_Esri
Hi Cindy,
To answer your question, Audio can only currently be added in the body of the main story and in sidecar narrative panels. I'm unsure if this functionality is expected for an upcoming release, best practice now would be to add the audio using a sidecar for a similar format. If you're using a clip on a hosted audio service, you could also use the Embed tool to place the audio near the slideshow!
Check out the Add Audio section near the bottom of the documentation here for the most updated recommended workflow: Add media—ArcGIS StoryMaps | Documentation
AbbyE_Esri
Hi Cindy,
CindyHamfler3
Thank you Abby!  I'm glad I wasn't missing it.  I do think it would be a cool option in slideshow as well.
OwenGeo
Esri Notable Contributor
Thanks for the feedback Cindy! We've noted this suggestion and are tracking it for future consideration.
Owen Evans
