How do i remove an event listener from Identify Task
1886
09-14-2020 11:54 PM
SteffiAntony
Seems like this should be simple, but I'm stumped. i need the functionality to be done in such a a way that on button click the identify task should be run properly on every click function on map . and on the same time when i press the same button again it should stop the API calls, and the event should be removed and vice-versa. how do it can be possible?
var identifyButton = dom.byId("identify")
on(identifyButton"click"function (evt) {
    map.on("click"executeIdentifyTask);
    //create identify tasks and setup parameters
    identifyTask = new IdentifyTask(textbox.value);
    identifyParams = new IdentifyParameters();
    identifyParams.tolerance = 3;
    identifyParams.returnGeometry = true;
    identifyParams.layerIds = [02];
    identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_ALL;
    identifyParams.width = map.width;
    identifyParams.height = map.height;
  function executeIdentifyTask(event) {
    identifyParams.geometry = event.mapPoint;
    identifyParams.mapExtent = map.extent;
    var deferred = identifyTask
      .execute(identifyParams)
      .addCallback(function (response) {
        // response is an array of identify result objects
        // Let's return an array of features.
        return arrayUtils.map(responsefunction (result) {
          var feature = result.feature;
          var layerName = result.layerName;
          feature.attributes.layerName = layerName;
              var Templates = new InfoTemplate("");
              feature.setInfoTemplate(Templates);
              return feature;
    // InfoWindow expects an array of features from each deferred
    // object that you pass. If the response from the task execution
    // above is not an array of features, then you need to add a callback
    // like the one above to post-process the response and return an
    // array of features.
    map.infoWindow.setFeatures([deferred]);
    map.infoWindow.show(event.mapPoint);
Tags (1)
ManishPatel
Hi Steffi Antony,
You can use the connect and disconnect to disable the events. And if I understand your requirement correctly, I have put together a sample for you. Have a look at it at Identify with Popup
The source code you can find at https://codepen.io/mrpatel/pen/OJNwMeE
Hope this helps.
Cheers!
Manish
Cheers,
Manish
ManishPatel
Hi Steffi Antony,
Hope this helps.
Cheers!
Manish
Cheers,
Manish
SteffiAntony
Thank you. Manish Patel‌ meanwhile i added 2 line of code.
    identifyClickHandler = on(map'click'executeIdentifyTask);
  identifyClickHandler.remove();
is this ok??
          // console.log(feature.attributes);
          return feature;
ManishPatel
Yes that will work too.
Cheers,
Manish
ManishPatel
Steffi Antony‌ please dont forget to mark the question as answered if the code provided helped to answer your question. This will help others to check when they need to find any answer.
Cheers,
Manish
Cheers,
Manish
