Graphics layer: element placement
809
09-13-2020 11:49 PM
helenchu
Occasional Contributor II
Hi
I'm trying to have an element placed at the bottom left corner of the selected feature but can't figure out how to do it.  I can place it at the center of the polygon fine but not at any other positions.  Your help is much appreciated.
while (foundCursor.MoveNext())
using (var row = foundCursor.Current)
var shape = row as Feature;
var poly = shape.GetShape() as Polygon;
myLabelGraphic.Shape = poly.Extent;
myLabelGraphic.Placement = Anchor.BottomLeftCorner;
UmaHarano
Hi Helen,
You have almost all the logic in
Once you get the polygon of your feature, you need to get its lower left corner coordinates. Use that for the graphic's shape property.  So like this:
var poly = currentRow.GetShape() as Polygon;
var lowerLeftX = poly.Extent.XMin;
var lowerLeftY = poly.Extent.YMin;‍‍‍
myLabelGraphic.Shape = //Create MapPoint using these coordinates.
Uma
UmaHarano
Hi Helen,
Uma
helenchu
Hi Uma Harano‌,
Line 12 returns an error : graphic shape property can not be null or empty.  What did I do wrong?  maxPoint is not null.
Thank you!
var maxX= poly.Extent.MMax;
var maxY= poly.Extent.YMax;
MapPoint maxPoint = MapPointBuilder.CreateMapPoint(maxX, maxY);
if (maxPoint != null)
 myLabelGraphic.Shape = maxPoint;
 myLabelGraphic.Placement = Anchor.CenterPoint;
 myLabelGraphic.Text = myText;
 myLabelGraphic.Symbol = myTextSymbol.MakeSymbolReference();
 graphicsLayer.AddElement(myLabelGraphic);
UmaHarano
On line 2, use XMax instead.  That should fix the issue.
Uma
helenchu
Hi Uma,
Silly me.  I was so certain I had XMax there.  Thank you very much!
