ldcarto
Survey123 Publishing Error-Table not found
Discussion created by ldcarto on Sep 11, 2020
Latest reply on Sep 18, 2020 by ldcarto
I have created a Survey123 form with no repeats.  There is a secured feature service created from a non-versioned, archived enabled, SDE table with GlobalIDs.  When I add the submission_url and form_id to the xlsx table and try to publish it, I get an error that the table specified in the form_id field is not found.  I am entering in the name of the feature class with the SDE table to that field, so I am not sure what I am doing wrong.
I am using Survey123 Connect 3.10, although the form was created under version 3.6
The feature class name is dw_external_lab_data3
I have attached the xlsx form for you to review.  If anyone has any ideas as to why it won't recognize the table, it would be greatly appreciated.
Thanks in advance,
Lisa
Outcomes
