Editing Table
808
09-07-2020 06:36 PM
VictorTey
Hi, I have a table layer and was wondering if there are any ways to modify or add contents to table using the Portal build in WebappBuilder(2d)? I looked through
Smart Editor, Edit and attribute widget and non of them seem to support table editing. Does this require a custom widget to support?
EduardBeneke
Hi Victor,
The only way I've found that allows this is you can add new related non-spatial records via the Smart Editor widget. If you are able to relate your table to a spatial layer then this might be an option?
EduardBeneke
Hi Victor,
VictorTey
Thank you Eduard Beneke‌ for that input . I think you are right as well. I will mark it as correct if nothing else comes along.
