I converted our Storm System in the Geometric Network over to the Trace but realize my storm piping should likely be complex edge. Is there any way to change this?
Solved! Go to Solution.
Looks like the only way is to delete the trace network and redo with complex edges.
Correct Robert Thomson You can simply delete the trace network and recreate this using complex edges.
