Dirty Areas that can't be resolved
1290
7
09-02-2020 11:10 AM
RobertThomson
Occasional Contributor II
I have dirty areas that can't be solved, in my case they are listed as stacked point features but I am unable to select any objects at that point. (see attached).
I did try unloading and reloading topology to no avail.
RobertThomson
The solution to this issue is to make sure you have no definition queries defined (delete or turn off if need be) and be certain in your feature class symbology to have a "all other values" defined.  For me it was a combination of both that was making the items creating the errors invisible and unable to be selected for a fix.
JonDeRose
Good morning Robert Thomson‌ -
Is the issue in this case that you cannot select the features which correspond with the point errors or that there is no corresponding point feature with a GUID matching that displayed in the Origin Global ID field?
Error 25 can generally be resolved by selecting the two points at that location and either relocating or deleting one of the two.  If you turn off the point errors sublayer are there any point features displayed in that location and are they set as selectable?
Jon
RobertThomson
I normally can fix Error 25 in the way you mention but in this case nothing is there to select.  I have the same issue on another Trace Network for our Water System, in one spot 12 stacked objects.
JonDeRose
Hi Robert Thomson‌ I've reached out via direct message to discuss a review of the scenario in more detail to see if we can get to the bottom of what might be going on.
RobertThomson
Where did you pm to?  Don't see any kind of mailbox here on GeoNet.
JonDeRose
Hi Robert Thomson‌  I sent a message which should be visible in your inbox to the left of your profile badge at the top of the screen.  I'd like to review your data if possible.  Could you reach out to me at -  jderose at esri.com?
VanessaSimps
Occasional Contributor III
We have several Error 25 showing up. In our feature classes we will often stack assets (a manhole, say) but give it a different active flag attribute. Asset can be "Proposed" or "Active". Because of this we have these stacked points. Doing some research,  the suggestion is to adjust the z value for the assets set as
"proposed" so they are no longer sharing the same x.y.z as the Active.
I have z enabled my features. I tried doing an edit where I selected all active assets and then use the Edit Vertices, BUT I can't batch update the z value. I have hundreds of these so I need a batch update option.
I found the Add Z Information tool as well as the Adjust 3d Z tool. Are these what Esri suggests we use to make these batch updates? I would need to do this if I use Trace Network or Utility Network.
Thank you in advance,
Vanessa
RobertThomson
