Python API timing out
970
08-31-2020 03:29 PM
GrantHaynes
Hi all, so I'm having some trouble with using the python api. I'm getting code 10054 when it goes to push data to AGOL and I can't figure out why.
import os, datetime, sys, traceback, time, arcpy, arcgis
from arcgis.gis import GIS
# Logging function to keep track of activity and errors
def Logger(logMessage😞
    try:
        with open("Log.txt""a"as logFile:
            logFile.write("\n{0} ; {1}".format(logMessage, datetime.datetime.now().strftime("%H:%M:%S , %m/%d/%Y")))
    except Exception as ex:
        print("Activity logging failed {}".format(ex))
def TruncateWebLayer(gis=Nonetarget=None😞
    try:
        lyr = arcgis.features.FeatureLayer(target, gis)
        lyr.manager.truncate()
    except:
        print("Failed truncating: " + str(target))
        sys.exit()
# User input dialog, note raw input for the file paths
userContinue = "N"
priorityMarkShpPath = input("Priority Mark Shapefile Path: ")
hex10kmShpPath = input("10km Hex Bin Shapefile path: ")
hex2kmShpPath = input("2km Hex Bin Shapefile path: ")
userContinue = input("Continue Y/N: ")
if userContinue in ("N""n""no"😞
    sys.exit(0)
try:
    if os.path.exists(hex10kmShpPath) and os.path.exists(hex10kmShpPath) and os.path.exists(priorityMarkShpPath):
        # Convert the input shapefiels into JSON
        print("Converting Shapefiles to JSON, this may take some time...")
        priorityMarkShpJSONResult = arcpy.FeaturesToJSON_conversion(priorityMarkShpPath, "priorityMarkShpJSON.json""FORMATTED")
        hex10kmJSONResult = arcpy.FeaturesToJSON_conversion(hex10kmShpPath, "hex10kmJSON.json""FORMATTED")
        hex2kmJSONResult = arcpy.FeaturesToJSON_conversion(hex2kmShpPath, "hex2kmJSON.json""FORMATTED")
        # Create a FeatureSet objects using the API from the JSONs
        priorityMarkNew = arcgis.features.FeatureSet.from_json(open("priorityMarkShpJSON.json").read())
        hex10kmNew = arcgis.features.FeatureSet.from_json(open("hex10kmJSON.json").read())
        hex2kmNew = arcgis.features.FeatureSet.from_json(open("hex2kmJSON.json").read())
        # URLs to individual layers of the service
        priorityMarkURL = r"#####"
        hex10kmURL = r"#####"
        hex2kmURL = r"#####"
        print("Logging into AGOL...")
        gis = GIS(url = "#####"username = "#####"password = "#####")
        gpsOnBmTestFS = gis.content.get("#####")
        foo = gpsOnBmTestFS[0].properties.capabilities
        # Remove all features from the existing web layers
        print("Truncating existing web layers...")
        TruncateWebLayer(gis, priorityMarkURL)
        TruncateWebLayer(gis, hex10kmURL)
        TruncateWebLayer(gis, hex2kmURL)
        # Reference the empty layers
        priorityMarkEmptyFl = arcgis.features.FeatureLayer(priorityMarkURL, gis)
        hex10kmEmptyFl = arcgis.features.FeatureLayer(hex10kmURL, gis)
        hex2kmEmptyFl = arcgis.features.FeatureLayer(hex2kmURL, gis)
        # Now add those featureset objects to the empty web layers
         # error happens here
        print("Publishing new Layers...")
        priorityMarkEmptyFl.edit_features(adds = priorityMarkNew)
        time.sleep(5)
        hex10kmEmptyFl.edit_features(adds = hex10kmNew)
        time.sleep(5)
        hex2kmEmptyFl.edit_features(adds = hex2kmNew)
        print("Completed Successfully")
    else:
        sys.exit("Invalid files please try again")
    print("Error see log for traceback")
    Logger(traceback.format_exc())
finally:
    print("Deleting Temp Files...")
    if os.path.exists("priorityMarkShpJSON.json"😞
        os.remove("priorityMarkShpJSON.json")
    if os.path.exists("hex10kmJSON.json"😞
        os.remove("hex10kmJSON.json")
    if os.path.exists("hex2kmJSON.json"😞
        os.remove("hex2kmJSON.json")
VictorTey
Grant Haynes
Can you check that priorityMarkNew you are adding is an array? Can you also print out priorityMarkNew
GrantHaynes
I figured it out, the datasets were too big so I wrote a function to break up the data and push those groups up.
JonPainter
Do you mind sharing the code with the function? I'm getting the same error as you above.
Thanks for your time.
