AnsweredAssumed Answered
Points display in Collector Classic and Explorer but not Collector
Question asked by JRougeaux on Aug 28, 2020
Latest reply on Aug 31, 2020 by rge-esristaff
I have several point layers that I would like to be able to use in Collector for ArcGIS with their current symbology.  The problem is they won't draw in Collector unless I change the symbology to something that is offered within ArcGIS Online.
I can use the same map and feature layers in Collector Classic or Explorer and everything displays just fine.  I've attached a couple screenshots showing this.  The symbology was created in ArcMap and the data published to Portal on a federated server.  The feature layers were then copied to AGOL using stored credentials and the web map created within AGOL.
Lines and polygons render in all three applications without issue.
Outcomes
